November 29, 2006, 08:33 |
URANS
I am going to perform the Unsteady RANS simulation to analyze cavity flow oscillations. I have no idea about the time step. I will be grateful if some one could tell me how can I choose the time step for the first order implicit time advancing.
November 29, 2006, 09:55 |
Re: URANS
Determine the oscillation frequencies of the cavity using Rossiter's formula. For the highest frequency you want to try to capture, plan on 50-100 timesteps per period. Back out the timestep. Using URANS you'll be lucky to get the second harmonic, so there's no point in going to a much higher frequency. And first-order time is not a good choice for simulating unsteady flows - you really need to use second-order time differencing.
November 30, 2006, 05:31 |
Re: URANS
In addition
If these calculations will be used to exstimate noise--> RANS is not the best way .... |
November 30, 2006, 11:10 |
Re: URANS
Thanks to all of you.
Starting a 3D URANS simulation from a converged 2D URANS simulation | Josh | Main CFD Forum | 2 | June 4, 2011 21:32 |
RANS and URANS | dshawul | Main CFD Forum | 0 | February 20, 2011 09:01 |
URANS in ANSYS CFX | brissyben | CFX | 3 | October 6, 2009 18:35 |
How best to set up a steady RANS problem that "should" be URANS? | LiveandLetDrive | Main CFD Forum | 2 | April 17, 2009 21:33 |
URANS and PHANS ?? | gorka | Main CFD Forum | 0 | November 11, 2002 09:12 |
