FVM Flux interpolation in Curvilinear Coordinates
Old   November 29, 2006, 05:57
Default FVM Flux interpolation in Curvilinear Coordinates
DSS
Hi All,
I am in process of developing a Finite Volume code. I am successsfull in a simple pure cartesian code. Now, when I attempted to extend it to curvilinear coordinates, I am struct with how to do the flux interpolation.
I was thinking if it is sane to just adopt the formulation into
dW/dx + dF/d(epsilon) + dG/d(eta) = Q
Where the flux terms contain the relevant transformations.
Is it valid? Because, physically, the equations are a bit different, as the face areas are now unity (computational space).
For the flux interpolation, if it is a simple averaging (less accurate), it is straight forward. But, if it involves some higher order interpolation schemes, how is the accuracy quantified? Wont the accuracy of the Jacobians, and terms like dx/d(epsilon) affect the accuracy of the solution altogether?
Your suggestions are greatly appreciated.
Old   November 30, 2006, 05:15
Default Re: FVM Flux interpolation in Curvilinear Coordina
Mar
Starting from dQ/dt +dF/dx +dG/dy=0
You have to transform the d/dx and d/dy derivatives in terms of the derivatives in the curvilinear coordinate(let's say csi and eta) system using the rules of derivation of composite functions. After that you can resonstruct a conservative form:
dQ*/dt + dF*/dcsi + dG*/deta=0
Where Q*=Q/J F*=Fdy/deta - Gdxdeta G*=-Fdy/dcsi +Gdx/dcsi
where J is the jacobian of the transformation.
Integrating in the control volume you can recover your Finite volume approach.
Old   November 30, 2006, 05:29
DSS
Thank you very much for clarifying my small doubt.
curvilinear coordinates Sibel Main CFD Forum 9 August 21, 2014 23:47
FVM in 1-D spherical coordinates lost.identity Main CFD Forum 0 January 17, 2011 10:06
Curvilinear Coordinates - (also for Harish) taw Main CFD Forum 1 November 3, 2008 06:44
Roe States (average) in curvilinear coordinates? Bernard Parent Main CFD Forum 3 February 29, 2000 12:02
ENO-schemes in curvilinear coordinates Mathias Main CFD Forum 0 January 4, 1999 07:12
