turbulent quantity goes -ve for intermediate run
Old   November 29, 2006, 00:37
Default turbulent quantity goes -ve for intermediate run
Sourabh
I have a viscous solution on very high mach over a bluff body, I try to run a turbulent code(compressible density based) using this solution as initial. After a few iterations or so my turbulent quantity goes negative, it happens with SA model and also with SST model. I tried to reduce CFD number (as low as 0.05) but it did not help...what could be the reason and is there any remedy?
Error trying to run steady-state sonicFoam dancfd OpenFOAM Running, Solving & CFD 2 February 12, 2013 04:15
What's the best order to run this simulation in? siw CFX 1 November 4, 2009 20:42
serial run fine, but parallel run diverged phsieh2005 OpenFOAM Running, Solving & CFD 2 October 6, 2009 09:33
About low Re number turbulent flows gorka Main CFD Forum 13 April 2, 2003 06:19
calculation of (turbulent) dissipation energy ? max Main CFD Forum 3 August 18, 1999 10:42
