Venturi Mixer Formula & Equations
Old   November 10, 2006, 19:44
Default Venturi Mixer Formula & Equations
Gen Woo
Hi all, I have been reading this forum for sometimes. I wonder if anyone can give me a hand or direct me to any website related. I am looking for information regarding how to calculate the Air & Gas flow (NG) thru a Venturi Mixer and sizing the Venturi Mixer correctly for the application. Any thing in this matter would be greatly appreciated. Regards, Gen
Old   December 6, 2006, 12:04
Default Re: Venturi Mixer Formula & Equations
elias nassar
i will be greatful if u could send me what have u got or direct me to any website related. I am looking for information on how to calculate the Air & Gas flow (NG) thru a Venturi Mixer and sizing the Venturi Mixer correctly or any thing related to cfd using fluent best regards elias
Old   December 11, 2006, 19:32
Thomas Kreher
Hi Gen Woo The flow through a good venturi is a function of the throat diameter (area) and absolute inlet pressure. The low pressure (vacuum) created in the throat of the venturi due to high velocity there will draw the ingredient into the flow stream and the exiting air flow will propel it outward. The mass of the ingredient will retard the venturi flow. Shoot me if I'm wrong but try this scenario. P1 = inlet pressure = 100 PSIG or 114.7 PSIA the throat dia D = .125 inches. Q = Flow in Standard Cubic Feet Per Minute (SCFM) W = approximately .075 pounds per Standard Cubic Foor (SCF) Then Q = 14.5 x .125 x .125 x 114.7 = 26 SCFM 26 SCFM x .075 Pounds = 1.95 Pounds per Minute (Air) For a Scientific Wild Guess if you subtract the weight of the amount of your ingredient flow per minute and multiply by about .75 for loss to turbulence and inefficiency you will be close enough for government work. For other orfice sizes and different pressures see my orifice chart on the International Fluid Power Society webb page. www.IFPS.org Then click on "White Papers". Merry Christmas
Guide: Writing Equations in LaTeX on the CFD Online Forums pete Site Help, Feedback & Discussions 27 May 19, 2022 04:19
CFD governing equations m.gos Main CFD Forum 0 April 30, 2011 15:21
Question about UDS equations tstorm Fluent UDF and Scheme Programming 1 January 11, 2010 14:04
Maths problem when deriving conservation of energy equations. Demonwolf Main CFD Forum 1 June 15, 2009 15:21
biogas venturi mixer transient analysis pedro Main CFD Forum 0 January 23, 2006 20:45
