Pressure calculation for internal problem using 3D panel method
Old   October 23, 2013, 11:53
Default Pressure calculation for internal problem using 3D panel method
Vitek is on a distinguished road
Hi everyone,
I have been developing a simple 3D panel code from scratch. The code is using vortex ring panels, iterative solving of the wake etc. The method works reasonably well for external flow, I started with simple objects, then wings, then a propeller, but the main goal is a water turbine in a turbine case (internal flow) with high pressure drop between inlet and outlet. I calculated the pressure acting on panels as -0.5*density*velocity^2 and then realized this can't be right for this type of problem, where total pressure doesn't stay constant, as in external aerodynamics but drops from inlet to outlet. I can calculate the total pressure drop from the mechanical energy extracted by the turbine but I would like to get the cp distributions etc...
What is the correct approach to calculating the static pressure on the blade surface?
Any help would be highly appreciated
Vitek is offline   Reply With Quote
Old   November 10, 2013, 12:15
I will try to formulate my problem more generaly.
I have potential flow solver that will give me the flow field around a rotating turbine blade. How to calculate the pressure at the blade surface, when there is mechanical energy being extracted?
Thanks for any clues,
Vitek
3d panel method, potential flow, pressure head, turbine
Simple method: pressure increases after some steps Hermano Main CFD Forum 4 February 3, 2015 12:07
stagnation pressure boundary problem mbgnfrx2 STAR-CD 2 November 26, 2012 00:55
Two pressure inlets problem Medison CFX 1 August 22, 2012 07:50
Total Pressure problem in a duct anveshkadimi FLUENT 0 July 20, 2012 14:19
specify a reference pressure point in FD method? Rui Main CFD Forum 10 August 30, 2010 09:50
