Cooling Rate Uniformity
Old   October 22, 2013, 23:26
Default Cooling Rate Uniformity
Qrate is on a distinguished road
Hello -
I am heat treating a flat plate in a laboratory vacuum furnace. The quenching gas is helium and the gas flow is axial . The plate must be quenched at a cooling rate that is uniform throughout the plate with little or no variability.
My question is about the plate orientation with reference to axial gas flow. Should the plate be in parallel, perpendicular or in inclined orientation with respect to the axial gas flow to achieve uniform cooling?
PLease help using the boundary layer concept.
Thank you.
Qrate is offline   Reply With Quote
Particle cooling rate - UDF papteo Fluent UDF and Scheme Programming 9 January 29, 2012 10:28
How to calculate phase flow rate? sangramroy FLUENT 0 January 11, 2012 14:02
cooling rate caesrinivas FLUENT 0 September 11, 2009 08:41
Plot heating and cooling rate (dT/dt) vs time Frederic FLUENT 0 February 6, 2005 05:00
Passive cooling system for batch reactor Darek Main CFD Forum 0 September 30, 2003 06:06
