Flow field measurement in turbomachinery!
Old   September 3, 1999, 11:24
Default Flow field measurement in turbomachinery!
Wanlai Lin
Dear Sir or Madam:
EVP (Emerson Ventilation Products, a division of Emerson Electric Corporation) is trying to obtain some testing data for velocity and pressure field in an axial flow fan, and a centrifugal blower. We are especially interested in the flow field around the tip clearance (for the axial flow fan), and velocity and pressure field inside the rotor blade passage. The average velocity is about 12 (m/s), and the static pressure increase is about half an inch of water (or 300 N/m^2).
We are looking for someone in USA who (a) had routinely measured the flow field in the turbomachinery with the matured technology (like LDV) (b) had the measuring device ready for use (c) is willing to help EVP measure the flow field of a axial flow fan and a centrifugal blower, with a reasonable labor fee.
Please correspond to Dr. Wanlai Lin (wlin@emersonvent.com) or Dr. Siddharth Singh Thakur (sst@tiger.aero.ufl.edu) for further information if you can help.
Thank you for your consideration.
Old   September 3, 1999, 12:11
Default Re: Flow field measurement in turbomachinery!
John C. Chien
(1). With so many commercial codes on the market, some of those even specialized in turbomachinery, most are suitable for low speed applications, I am surprised that you are looking for data. (2). I would strongly suggest that you first try out some of these codes first. Some of the codes should be able to handle the tip clearance also. (3). Look for someone to do testing in a CFD forum? (hard to understand)
Old   September 3, 1999, 12:34
clifford bradford
John's right for that kind of thing some code should be good for the job. however if you really want to do measurements. Dr. Budugur Lakshiminarayana (b1laer@engr.psu.edu)at penn state is into that and he has all the required equipment
Old   September 3, 1999, 13:06
Md. Ziaul Islam
Turbulence Research Laboratory, University of Maryland at College Park
Facilities Windtunnel
Hot Wire Anemometry
The Turbulence Laboratory has extensive expertise in measurement of turbulent flow properties using multi-sensor hot-wire anemometry techniques. A unique, miniature, twelve-sensor hot-wire probe has been developed in this laboratory. It is capable of simultaneously measuring the velocity vector and the defining property of turbulence - the vorticity vector.
Two AA Lab Systems 12-channel constant-temperature anemometer systems are used with the hot-wire probes. Two constant current modules for high frequency temperature measurements are also available.
I am guessing that if you contact The Turbulence Research Laboratory then the personnels working at the lab. can find you an expert for flow measurements experimentally.
AND GOOD LUCK
velocity of massless particles and velocity of flow field in same coordinate payam_IUST FLUENT 0 October 19, 2009 00:24
Porous domain in a flow field rikio CFX 7 August 25, 2009 23:39
how 2 freeze 1 phase flow field & start lagrangian KK CFX 5 February 14, 2008 17:48
flow field residuals into posdat? nicola Siemens 0 February 9, 2007 11:54
computation about flow around a yawed cone Tylor Xie Main CFD Forum 0 June 9, 1999 08:33
