October 27, 2006, 10:59 |
M6 ONERA Wing profile
Hi all !
I'm a student and Iwould like to simulate an M6 ONERA wing: http://www.grc.nasa.gov/WWW/wind/valid/m6wing/figb1.jpg (with CFX). The first problem I have is to model this wing with a CAD software. I already found the profile : http://www.grc.nasa.gov/WWW/wind/val...ng/airfoil.txt but I guess that the profile is not the same near the fuselage and and the end of the wing... Does anybody knows how to model this (i.e how to find the profils at the end of the profile) ?? Thank ! |
November 19, 2006, 06:25 |
Re: M6 ONERA Wing profile
Hi, I'm simulating an Onera M6 too and I have the same problem, no Onera CAD found. I have made some CAD models but I'm not sure they fit well a real wing since I rounded the tip section of the wing, if you want I can send you a copy.
Excuse me for my bad english! |
November 19, 2006, 18:54 |
Hi, I made a cad model, based on a file I found on this site http://www.grc.nasa.gov/WWW/wind/val...ng/m6wing.html
The coordinate is for a 1-meter chord (you have to adapt it to your case afterwards). P.S : No worries for the English (I'm French... I suppose you're Italian... so no worries P.S2 : I've got a model too if U want it See U |
November 20, 2006, 11:45 |
Good! I made my model with the same coordinates, if you send it to me I can confront. My problem, as I said in a previous message, is the tip of the wing. I use starccm+ for simulation and my residuals are not good, say 10e-2 with approximately 10e6 polyhedrals and y+ 2.
Yes, I'm Italian. Thanks |
November 20, 2006, 11:54 |
Hi, I've just realised that I forgott to change the name of my previous message... it was not Peter, but me, Cyril
I'm using CFX (not the best choice, but My University chose it ;(... but I'll try with Fluent If I have some time) I didn't start the simulation yet, I have to work on the mesh firts (bloody CFX... grrrr !!) I'll let you know ASAP what results I have. P.S: What are your boundary conditions (speed, pressure...) and what size did you chose for your simulating volume ? (I took 1 chord before the leading edge, 2.5c behind the trailing edge, 2.5 up) and mesh 3D-tri |
December 7, 2011, 04:17 |
#6 | |
Rep Power: 15 |
July 16, 2012, 01:38 |
Need the profile too
#7 | |
Moore
Rep Power: 14 |
I also would like that CAD file, Have you received it and could you please email that to me? chumu.au@gmail.com thanks a lot |
November 7, 2012, 07:50 |
Rui Vizinho de Oliveira
Rep Power: 15 |
Hi shiyun,
Did you get the ONERA M6 3D geometry ? If you did, can you please send it to me ? My email is ruivizinhodeoliveira@sapo.pt Best Regards Rui Oliveira |
November 20, 2012, 09:27 |
#9 | |
Bambang
Rep Power: 14 |
I have an ONERA M6 multi-block structured grid, and I should be able to provide the grid points in an IGES format. You might want to consider doing simulations through eCFD, by which you would be able to get cgns, data files in tecplot format and selected visualization of the flow solution, say, for comparison with the results from your code. If you are interested please contact me through http://ecfd.nlr.nl/index.php/contact-us-now Best regards, Bambang |
November 29, 2012, 11:07 |
Mr Malik
#10 |
malik
Rep Power: 14 |
Hi Francesco P.,
CAn you plz send me the CAD geometry of ONERA m6 wing that I can open in ICEm. Plz i need it urgently. Thanks Kind regards, Malik |
November 29, 2012, 11:13 |
#11 |
malik
Rep Power: 14 |
Hi, Peter
Can you please send me the Geometry of ONERA M6 wing that i can open in ICEM. I need it urgently plz. Thanks Kind regards, MALIK |
November 29, 2012, 12:50 |
#12 |
Rep Power: 15 |
I can send you, tell me your email
December 2, 2012, 14:31 |
#13 |
malik
Rep Power: 14 |
Hi RuiVO,
My email is s.malik.eng@gmail.com Plz send me the geometry on ONERA m6 wing that I can open in ICEM. I will be really thankful. Regards, Malik |
January 23, 2013, 08:47 |
Malik
#14 |
malik
Rep Power: 14 |
Hi RuiVO,
can you plz send me the 3D mesh of ONERA M6 wing that i open in ICEM and then run in fluent. I need both coarse and fine mesh. i am in urgent need. my email is (s.malik.eng@gmail.com) Many thanks in advance |
January 23, 2013, 09:17 |
#15 |
venki
Rep Power: 15 |
Please check in advance tutorial. its there
May 23, 2013, 12:40 |
#16 |
June 30, 2013, 10:45 |
Help>>>>>>
#17 |
XU YU
Rep Power: 13 |
I am looking for Onera M6 Wing geometry. If anybody got, please send it to me... xuyu1988@hotmail.com thanks a lot...
June 30, 2013, 10:47 |
Help>>>>>>
#18 | |
XU YU
Rep Power: 13 |
December 31, 2016, 15:59 |
Onera M6 wing .geo file
#19 |
Masood
Rep Power: 10 |
Hi guys,
I created a oneraM6 wing 3D geometry using gmsh, but when I try to make a 3D mesh I'm getting an error "core dumped". can anybody tell me how to remove this error. or If anyone is having a structured 3d oneraM6 wing geometry file or .geo file that can be open in gmsh. please send it to me @ mdmasood36@gmail.com I really appreciate you help, I have to complete my project. Thank you. |
Onera M6 Wing Mesh | salvoblack | OpenFOAM | 10 | January 23, 2021 12:52 |
Trouble when using MUSCL scheme on ONERA M6 wing | Aurélien | FLUENT | 2 | January 23, 2013 08:42 |
Wing profile and stall | Jens | Main CFD Forum | 0 | June 26, 2007 10:42 |
wing profile of a plane | student | Siemens | 3 | August 25, 2006 11:09 |
Onera Wing Wall function? | Dianhong | Main CFD Forum | 0 | November 21, 2003 21:19 |
