How to debug .so library in the source code level |
October 22, 2006, 08:04 |
I compiled a Fortram/c/c++ mixed language program using intel compilers with options: -g, and much dynamic library .so and an executive were generated, but when trying to debug it using PGDBG(from PGI group), the debuger aborted after a moment, and during this short interval, I foung the memory and swap space were used out, and this case, I do not know what is the reason. For the same program, when debug using TotalView, I can not see the source code and of course, I do not know where the program goes, Can anyone help me on this problem. Thanks in advance.
Li |
October 23, 2006, 08:43 |
Re: How to debug .so library in the source code le
Unless you have the source code for the library your debug options are going to be limited, because the compiler has no way of instrumenting a binary library for debugging. You may be stuck with the tried-and-true method of putting in write statements to determine where the code is dying.
October 23, 2006, 10:29 |
I have all the source code of it, compilered with -g, but it seems that Totalview can not know where to find the source code??
Git or other systems for source code and documentation management | olesen | OpenFOAM | 4 | November 12, 2009 11:03 |
modify the source code of simpleSRFFoam solver | Pirlo | OpenFOAM Programming & Development | 0 | October 19, 2009 09:49 |
Understanding k-omega SST model source code | tmhonka | OpenFOAM Programming & Development | 1 | September 8, 2009 08:33 |
heat equation solution source code | john | Main CFD Forum | 1 | May 28, 2004 00:41 |
Which is better to develop in-house CFD code or to buy a available CFD package. | Tareq Al-shaalan | Main CFD Forum | 10 | June 13, 1999 00:27 |
