differencing schemes for 3-D Convection-diffusion problems
Old   September 16, 1999, 05:16
Default Re: differencing schemes for 3-D Convection-diffusion problems
  #21
Bob Roach
But you still didn't answer Andy's question as to the effective Reynolds number. If it is low, you may be able to get away with a scheme that is more central. If you can stand it, a fine grid will reduce the cell Reynolds number to the point where central difference would be the preferred stencil. Apart from that, John Chien's advice about the varying coefficients being included in the differencing is extremely important if you want to keep from introducing non-conservation type errors which definitely delay convergence. Good lucks.
Convection discretization schemes for LES sek OpenFOAM Running, Solving & CFD 38 July 31, 2017 15:30
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
Best Method for solving 2d convection diffusion vishal Main CFD Forum 2 September 27, 2008 18:19
AMG parallelisation and convection schemes christian OpenFOAM Running, Solving & CFD 3 December 17, 2007 09:21
Recommended convection schemes for swirling flow in diffuser hani OpenFOAM Running, Solving & CFD 12 August 23, 2005 12:05
