Reynolds number in pressure driven flow
Old   October 1, 2013, 13:41
Thumbs up Reynolds number in pressure driven flow
Liam
Many is on a distinguished road
Anybody knows how to compute Reynolds number for a pressure driven flow? I have read something in the fórum about Bernouilli and mass conservation, but I am not sure if this can be used for obtaining the velocity for Reynolds number calculations...
I have two inlets, a wall and one outlet. I guess characteristic lenght is hydraulic diameter, but if I had two inlets, should I use as lenght the sum of the hydraulic dyameter of both inlets?
Sorry for that stupid questions, sure somebody can answer it easily...
Thanks!
Many is offline   Reply With Quote
Old   October 1, 2013, 14:00
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Thanks!
You just have two characteristic Reynolds numbers, each for inlet of diameter D1 and D2. The viscosity is the same. Just need to know the two velocities. If you are using a computation with non-dimensional variable, use the characteristic diameter and velocity that characterize your flow.
Note also that the Reynolds number is also a local variable as it depends on the developping of the boundary layer along the wall
FMDenaro is offline   Reply With Quote
Boudaries for bouynat driven flow with additional mass flux at inlet Charon CFX 2 April 27, 2013 09:02
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 05:15
High Reynolds Number Incompressible Flow Nick Lavery Main CFD Forum 3 February 19, 2002 16:47
pressure gradient term in low speed flow Atit Koonsrisuk Main CFD Forum 2 January 10, 2002 11:52
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 22:31
