CFD simple Examples
Old   October 18, 2006, 02:20
Default CFD simple Examples
Prasann S Desai
Hello Friends, I am MTECH Chem Engg doing my project in CFD. I am looking for some simple examples which can be easly understood and solved. thankx
Old   October 18, 2006, 08:05
Default Re: CFD simple Examples
pc
Try some basic analytic cases from your fluids books: 1) inviscid flow over a cylinder 2) flat plate boundary layer (Blasius solution) 3) 2D oblique shock past a wedge/cone of known angle 4) etc. etc.
Old   October 18, 2006, 16:21
dontknow
Lid driven cavity...
Old   October 19, 2006, 10:18
simon
Are you using a commercial code such as Fluent say, or are you writing your own code ?
I'd start with a 1D simulation through a convergent-divergent nozzle, this is very easily validated using isentropic flow and normal shock relations from theory. It is a useful and interesting study as it can be used to show how a change of boundary condition can result in drastically different flow behaviour even though the geometry remains unchanged - e.g. how a change of pressure ratio can result in subsonic flow throughout, a normal shock forming at the throat, or a normal shock forming in the divergent section downstream.
I can't think of too many 2D cases where an analytical solution may exist apart from oblique shock formation over a wedge..again the shock characteristics ( strength, position etc ) can be calculated from theory giving some validation for you.
A good start point would be the book by Anderson ( Computational Fluid Dynamics The Basics With Applications ) - you will find it in the books section on this site.
Hope this helps, Simon.
Old   October 30, 2006, 04:30
Munish
Hi friends i have project in CFD i want some solved codes related to CFD using SIMPLE/MAC Algorithm
Need help on simple CFD case. (using CFD-ACE+) Sean Main CFD Forum 1 September 30, 2005 11:05
A simple CFD code for teaching basic CFD? Christoph Lund Main CFD Forum 13 September 14, 2005 05:36
CFD Wiki - We Need More Help Jonas Larsson Main CFD Forum 13 September 13, 2005 18:36
ASME CFD Symposium, Atlanta, 22-26 July 2001 Chris R. Kleijn Main CFD Forum 0 August 1, 2000 11:07
public CFD Code development Heinz Wilkening Main CFD Forum 38 March 5, 1999 12:44
