Crude oil Pipeline over river banks
Old   October 13, 2006, 18:56
Default Crude oil Pipeline over river banks
Typical question in OIL and GAS
I was wondering if some of you can recommend papers or web site on a typical example for the oil and gas industry (on shore):
When the crude oil is produced and separated from gas and water in the flow station at the rig it needs then to be carried to a processing and distribution point (refinery) via pipeline. Sometimes the pipeline needs to go over a river. When it is hot or cold, the radiation on the water (reflected) can be quite different from the radiation on the ground (absorbed). There is also evaporation of the water if the pipeline stays overground/overwater. Another solution is to put the pipeline laying on the riverbed, but there could be problems with whatever is carried by the river (rocks, broken trees, etc...).
In any case there is a temperature change when the pipeline crosses a river. FSI and Thermal FSI + CFD should be required in the model.
Any suggestion to point to (publications)? which software package can model good pipe flow with heat transfter + the close river environment.
Thank you
Carl.
Old   October 14, 2006, 17:15
Default Re: Crude oil Pipeline over river banks
Angen
In Canada, most pipelines are UNDER a river bed so you can avoid all the problems you mentioned. What you need is to put your pipeline deep enough to avoid it being flooded. It seems to me that it is even a law to put a pipeline under the river bed.
Angen
Old   October 15, 2006, 09:33
Harry
In remote countries like Indonesia or South America, I don't think they will dig, with all the aligators, leeches, pirhanas, malaria, etc... For maintenance, then the river bed will have to be excavated again.
May be you can find some relevant example there: http://www.ansyssolutions.com/
H.
estimation erosion in oil and gas pipeline alan81 CFX 23 August 18, 2014 07:26
oil aeration problem wprostaff FLUENT 0 July 19, 2011 16:41
Model Crude oil emaronchi CFX 3 August 25, 2010 04:42
evaporation of crude oil from surface Søren CFX 0 August 14, 2007 06:02
simulation crude oil annulas well A.NASER FLUENT 1 May 7, 2004 15:08
