October 9, 2006, 06:24 |
An advice on general fluid meca knowledge ?
Hi all, I've just designed an airfoil, and I'm wondering how to predict the aerodynamic performances...
I don't know if there are theoritical or numerical methods... Do you know some ? (Even only the name, and I would be able to look in books, or else.) Many thanks !! Sak |
October 9, 2006, 07:59 |
Re: An advice on general fluid meca knowledge ?
if you send me your email (mc02610@mail.ntua.gr) i can send you a simple Fortran code you'll be able to use it if you are familiar with Bezier points geometry
October 9, 2006, 09:53 |
I guess that's a numerical solution...
Do you know some theoritical ways ? Is there any way to solve or approach the solution this problem by quick hand made formulas ? By the way, I'm also intersested in your Fortran code... ! |
October 9, 2006, 10:26 |
Try Funfamentals of aerodynamics by anderson ,chapter 4.7
Its about Thin airfoil Theory . You place a number of vortex on the chort line, its easy you'll get it. |
Fluid Structure Interaction | Apollo | Main CFD Forum | 5 | July 4, 2011 16:15 |
Fluid dispersion into a free stream - Advice needed please | LSF | FLUENT | 0 | April 12, 2009 08:45 |
Biological tissue fluid interaction | bretttully | OpenFOAM Running, Solving & CFD | 1 | February 19, 2008 13:26 |
CFD Code Choice and General Advice | Alex Pope | Main CFD Forum | 26 | April 25, 2007 11:54 |
Fluid Structure Interaction | Apollo | FLUENT | 8 | July 7, 2004 17:54 |
