Karman vortex street: boundary conditions for velocity, pressure
Old   September 12, 2013, 18:07
Default Karman vortex street: boundary conditions for velocity, pressure
nschloe is on a distinguished road
Hi all,
with incompressible Navier-Stokes, I'd like to build a PDE for Kármán's vortrex street and I wonder what consistent boundary conditions for the velocity u and the pressure p would be.
While on the obstacle and the tube walls I'd employ no-slip-no-penetetration for u and free boundary conditions for p, i.e.,
u = 0,
n.grad(p) = 0,
(where n is the outer normal), the situation for the inlet and outlet are less clear to me.
To force a inflow on the left, one could certainly use something along the lines of
u = ((y-tube_lower)*(tube_upper-y))
(0.0 )
How about the pressure here, though? What about the outlet?
nschloe is offline   Reply With Quote
Old   September 12, 2013, 18:21
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Originally Posted by nschloe View Post
Hi all,
u = 0,
n.p = 0,
(0.0 )
For incompressible flows, the "pressure" is not a thermodinamic function but it enforces the divergence-free velocity field by means of the Poisson equation.
Said that, BC.s for velocity and pressure can not be prescribed independently. If you fix the velocity, the pressure BC for the Poisson equation is constrained by the congruent Neumann condition.
FMDenaro is offline   Reply With Quote
Old   September 12, 2013, 18:40
That is my understanding as well.
If I see things correctly, I can use n.grad(p)=0 everywhere if n.u is specified everywhere, and in this case I have to make sure that \int_{boundary} n.u = 0 to have a consistent PDE. -- That corresponds with the incompressibility assumption.
In the case of Karman's vortex street, though, I don't want to prescribe n.u at the outlet.
What is the consequence for the pressure boundary conditions? Will I have prescribe the pressure somewhere?
Old   September 13, 2013, 07:45
outlet can be managed in terms of some free-stream condition, e.g. n.grad (u) = 0. That leads to change the source term and the coefficients of the pressure matrix.
It is quite easy to find in literature papers about the outlet bcs.
Old   September 15, 2013, 16:05
leflix is on a distinguished road
Hi all,
I don't understand what you mean.
Navier-Stokes equations are the PDE which rule the Karman's vortex street as any flow!!
the best ones are Orlansky outlet boundary conditions:
du/dt + ubarre du/dx =0
dv/dt + ubarre dv/dx =0
dp/dx=0 if you use SIMPLE like algorithm or projection method for velocity-pressure coupling algorithm
ubarre is the mean longitudinal velocity in the domain
here d /dt or d/dx are the partial derivative.
leflix is offline   Reply With Quote
boundary conditions, navier stokes, vortex street
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 18:44
CFX13 Post Periodic interface EtaEta CFX 7 December 8, 2011 18:15
Boundary Conditions : Total Pressure or Velocity Gearb0x OpenFOAM Running, Solving & CFD 2 February 28, 2011 22:18
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
