blowing boundary condition
Old   September 12, 2013, 08:03
Question blowing boundary condition
Jochen is on a distinguished road
Hi guys,
i am currently working on a problem and am kind off stuck at the boundary condition.
i am computing a super sonic Ma=2.6 2d flow over a flat plate with a slot from which a subsonic cooling film is emmitted using a WENO scheme and a flow solver not written by me.
the problem is the boundary condition at the slot: a constant massflow rate should be blown into the boundary layer.
the mass flow is defined as follows:
massflow rate dot m=rho_c*v_c*A (1)
therein rho_c*v_c=F_c (2) is a given as the blowing rate F_c. the blowing rates used are small F_c=0.065
also the temperature of the coolant gas is give T_c the area of the slot A is also known.
the pressure is taken from the flowfield above the slot p_c
and is used to compute the density rho_c as such:
rho_c=p_c/T_c (3)
for the implementation of the boundary condition i need
the pressure p_c which is taken from the flowfield an is not a constant
the density rho_c which is also not a constant see (3)
the velocity v_c=F_c/rho_c=F_c/p_c
my questions/problems are:
(a) when i compute the solution using these boundary conditions do i get a constant massflow rate?
(b) also by using the pressure from the flow field the density rho_c and the velocity v_c change and cause oscillation how can this be avoided?
(c) how would you guys implement a constant massflow rate?
(d) does it make sense from a physics standpoint to prescribe the pressure p_c instead of getting it from the flowfield?
thanks a lot for your help
Jochen is offline   Reply With Quote
Old   September 13, 2013, 07:15
Exclamation further explanation
so a day has gone by and nobody was able to help me
anyway to further elaborate on my problem:
the boundary conditions in the solver i am using are prescribed for the slot from which the coolant is emmitted as follows:
the wall is situated between to cells 4 and 5
the wall normal vector points in y direction (north);
to get the pressure from the flowfield the following is used:
p[0]=p[9]
p[1]=p[8]
p[2]=p[7]
p[3]=p[6]
p[4]=p[5]
this essentially says dp/dy=0
the density is defined as the pressure from the flowfield divided by the given coolant temperature T_c:
rho[0]=p[9]/T_c
rho[4]=p[5]/T_c
so now the density is a function of the flowfieldpressure.
finally the velocity is set using the given blowing rate F_c:
v[0]=F_c/rho[0]
v[4]=F_c/rho[4]
all variables are double precision.
if i then compute the massflux:
dot m/A[0]= v[0]*rho[0]=(F_c/rho[0]) *rho[0] it should equal F_c.
running this code the computed dot m/A shows a difference from F_c in the order of F_c-dot m/A=10^-13
after ~ 20,000 iteration steps the computed d m/A equals F_c.
is the formula for the massflux correct?
is it physically correct that the rho[0] cancels out for the analytical solution?
thanks again and any comment is welcome.
boundary, condition, filmcooling, massflow
Radiation interface hinca CFX 15 January 26, 2014 18:11
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 18:44
Setting outlet Pressure boundary condition using CAFFA code Mukund Pondkule Main CFD Forum 0 March 16, 2011 04:23
How to set boundary condition in Fluent for the fo Peiyong FLUENT 1 November 10, 2006 12:44
