Reg: Supersonic flow past backward facing step
Old   September 30, 2006, 06:07
Default Reg: Supersonic flow past backward facing step
kiran
Dear Friends,
I am working on supersonic flow (M=2.5) past a backward facing step. I make use of an inhouse 2D finite volume Euler code. I have the following doubts.
1. Which among Roe, VanLeer and AUSM would be a preferred choice ? I find that the pressure on the base (step) is wrongly predicted when I use Roe scheme, but the predictions are better (although not in good qunatitative agreement with experiments) when VanLeer scheme is employed.
2. What is the maximum value of Mach number achieved in the recirculation zone ?
3. Is it possible that viscous solution with a suitable turbulence model may give me improved results? If so, what turbulence model is recommended? I have used Roe + Baldwin Lomax and my base pressure predictions are not significantly different from those of an inviscid code
Thanks in advance
Regards,
Kiran
backward facing step flow student Main CFD Forum 6 June 9, 2013 12:17
Inviscid flow over a forward/backward facing step Abhijit Tilak Main CFD Forum 3 February 16, 2005 10:18
backward facing step flow senthamarai kannan Main CFD Forum 0 January 22, 2005 06:01
Backward Facing Step Pete Main CFD Forum 5 June 28, 2000 22:40
Backward facing step Chris De Langhe FLUENT 1 March 5, 2000 17:04
