fluent nox module for nox reduction using sncr
Old   September 28, 2006, 14:26
Default fluent nox module for nox reduction using sncr
asim ibrahim
hello every body i am modeling a combustion rig. i am using specie transport model and diffusion flame.
my major problem is related to fluent nox module. i want to simulate reduction of nox using SNCR. i did employ the fluent nox module and make the sncr option on but i didnot get the results as solution didnot proceed any further and fluent gives the message that " solution is converged". i also have difficulty in defining ammonia injection.
any body can give me some hint. plz help me waiting for mail thank you
Old   October 9, 2006, 08:24
Default Re: fluent nox module for nox reduction using sncr
cristina
Maybe you already find a solution.
There is an indication from the Fluent User guide which may help you:
"When you begin iterating with the NOx model enabled, FLUENT may report that the solution has converged after the first iteration. This is due to the lack of ignificant levels of pollutants in the solution. You can force FLUENT to continue iterating by repeated iteration requests. Once pollutants appear in the solution, FLUENT will continue iterating on its own until a steady solution is achieved."
Old   October 10, 2006, 12:09
asim ibrahim
yes that i already know this thing from the fluent help available to me but it didnot actually help me. may i ask you that did u have used that model succesfully. if u have used that model then i will ask u again about my problem more comprehensively. thanks
Old   October 11, 2006, 03:07
cristina
no I did not use this model. I was reading about when I found your message. good luck.
Two questions on Fluent UDF Steven Fluent UDF and Scheme Programming 7 March 23, 2018 04:22
Different Results from Fluent 5.5 and Fluent 6.0 Rajeev Kumar Singh FLUENT 6 December 19, 2010 12:33
how to calculate fuel nox in fluent ssj FLUENT 6 May 9, 2007 05:52
can Fluent model CO, NOx? tomas FLUENT 2 June 10, 2005 04:36
NEW flow-induced noise module in FLUENT 6?? jon FLUENT 0 March 18, 2002 05:18
