How to compile this kind of code
Old   September 21, 2006, 16:44
Default How to compile this kind of code
Harry
Hi, Guys
How to compile the following fortran code by f77
Program 'test'
# include "head1.h"
# include "head2.h"
a=1
b=2
c=3
call test(b,
& include "head2.h"
end
subroutine test(1,
& include "head2.h" # include "head1.h"
print*,a,b,c
return
end
head1.h includes the following line
# define _tes a
head2.h includes the following line
# real*8 c
Old   September 21, 2006, 17:08
Default Re: How to compile this kind of code
Harry
a interesting thing. a old style of programming. it seems the code is written by mixing languages c and fortran. the main part is coded by f77 except the definition of variables by C language. Since the code never call any C-language subroutine, I really get lost. How to complie this type of codes? any hint would be appreciated.
Old   September 21, 2006, 18:38
andy
Change the name of the file from program.f to program.F and it will compile on almost all a unix-like systems.
The statements beginning with #include are for the cpp program which is the C pre-processor. Capitalising the extension is the naming convention for first running a program through cpp on unix-like systems.
FORTRAN, unlike C, is a portable language and does not understand directories which are different on different systems. Hence FORTRANs include can only look in the same directory as the main file. This is not how include files are usually used for larger programs hence the switch to using cpp for many using unix-like systems.
Old   September 21, 2006, 23:30
Harry
Done!thank you very much.
PV3FoamReader compile error.... PEM_GUY OpenFOAM Installation 6 April 5, 2010 18:22
What is the Better Way to Do CFD? John C. Chien Main CFD Forum 54 April 23, 2001 09:10
user friendly cfd code waqar Main CFD Forum 19 August 18, 2000 17:31
own Code vs. commercial code Bernhard Mueck Main CFD Forum 10 February 16, 2000 11:07
State of the art in CFD technology Juan Carlos GARCIA SALAS Main CFD Forum 39 November 1, 1999 15:34
