Durukan TAMKAN
Rep Power: 0 ![]() |
Hi;
While i was searching, i found the Matlab Tornado codes that is very useful for Vortex Lattice Calculations. I am trying to run tornado studentbatch.m file but i took the related error: ??? Reference to non-existent field 'aftfuse'. Error in ==> bodyplot at 6 Z=Z.*body.length(i).*(body.aftfuse(i)); Error in ==> studentbatch at 148 bodyplot(body); As a result i added "body.aftfuse= [ 0.5 0.5 0.5]; " to the studentbatch.m then i get the following error : ??? Attempt to reference field of non-structure array. Error in ==> iterateAlpha at 52 CW=-(weight.gravity*weight.unitvector(3)+TZtot)/qS; Error in ==> fTrimCLconstEW at 124 [state,results,lattice,ref]=iterateAlpha(engine,state,weight,qS,results,geo,l attice,ref,solvertype,max_iterations); Error in ==> studentbatch at 175 [results,rudderangle,state,engine,converged]=fTrimCLconstEW(geo,state,trimaxis,trimwing,trimru dder,solvertype,engine,weight,results) Thus ; i added "weight.gravity=[9.81];weight.unitvector=[0 0 -1]; and changed weight=100 as weight.ew=100; " in the studentbatch.m Because of changing "weight" as "weight.ew"; I modified all "weight" as "weight.ew" in the fTrimCLconstEW[/B] Then i faced with the following; ??? Input argument "CD" is undefined. Error in ==> iterateAlpha at 53 CZ0=results.CZ+CD(3); Error in ==> fTrimCLconstEW at 124 [state,results,lattice,ref]=iterateAlpha(engine,state,weight,qS,results,geo,l attice,ref,solvertype,max_iterations); Error in ==> studentbatch at 177 [results,rudderangle,state,engine,converged]=fTrimCLconstEW(geo,state,trimaxis,trimwing,trimru dder,solvertype,engine,weight,results) Even i tried, i could not find what cd refers to. Because there are many cd values in the code and it seems like a matrix( because it's 3th component is used infTrimCLconstEW). ![]() The link of related code: http://www.redhammer.se/tornado/DL.html |
error, matlab, tornado, vlm |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 18:00 |
c++ libraries and solver compiling | vaina74 | OpenFOAM Installation | 13 | February 3, 2012 17:43 |
[OpenFOAM] Saving ParaFoam views and case | sail | ParaView | 9 | November 25, 2011 15:46 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
user defined function | cfduser | CFX | 0 | April 29, 2006 10:58 |
