Modelling a Racecar Airbox
Old   September 19, 2006, 07:29
Default Modelling a Racecar Airbox
Mark Braithwaite
Im just about to start my third year at University and so have a lovely big dissertation to do!
I do some part time work for a race team, and they asked me if I would like to do my dissertation on a project for them.
The project is to analyse two different airbox designs they have, which have about a 10-15hp difference in them, and then come up with some possible design changes to make them more efficient.
I was wondering how difficult it is to model the "suck" of the engine using CFD? I have heard it can be a bit tricky, but didn't know if this meant its the sort of thing which just takes a little while to get right or if it requires decades of CFD experience (which I don't have!!)?
Cheers in advance, any help appreciated!
Old   September 19, 2006, 12:18
Default Re: Modelling a Racecar Airbox
Joe
Cant you get experimental data for the intake and apply that as a BC to the airbox whose geometry can then be slaved to an optimisation algo? Seems like a simple place to start ...
Old   September 19, 2006, 13:42
Mani
...maybe too simple. This problem seems hardly worth a dissertation because it just requires an application of well established methods, but it's good for a Master thesis.
Old   September 20, 2006, 04:39
Steve
Standard F1 practice is to use a coupled 1D/3D model. The 1D model provides the "suck", whilst the 3D model looks after the complex flow into and inside the airbox.
Old   September 20, 2006, 06:27
Mark Braithwaite
Ah I see, would something like GT Power be able to provide the 1D model for it?
I know at Uni we are using Fluent for the CFD and I've seen the two can be couple so if this is the case then that looks like the best way forward.
I presume it would just be a case of getting the engine info from the engine supplier (I was going to do a project using GT-Power anyway so sort of know what info would be required).
Old   September 20, 2006, 06:29
Mark Braithwaite
In fact, I've just checked on the Fluent website and found this article:
http://www.fluent.com/solutions/auto...r_coupling.pdf
This looks like the sort of thing you were talking about I think?
Old   September 20, 2006, 07:45
Steve
Yes. Most commercial 1D engine codes couple to at least one of the commercial 3D codes. Here's another example with some more technical details shown:
http://www.ricardo.com/download/pdf/wave_vectis_06.pdf
Modelling unsteady 2D aerofoil drag xlxc34 Main CFD Forum 0 June 24, 2011 05:42
Advice on multi-phase flow modelling Martin Main CFD Forum 3 October 14, 2008 06:16
Unsteady modelling technique? Carlos FLUENT 0 September 26, 2008 12:37
how to ensure that your modelling is correct rvndr Main CFD Forum 7 March 1, 2004 13:21
Computational Modelling of Vortex Separators May Lim Main CFD Forum 6 November 13, 1998 13:36
