September 18, 2006, 05:40 |
BC for o-grid help
May I know what should be the boundary condition for a cylinder in free stream in an o-grid?
I wonder if this is correct: flow is coming from left to right fixed inlet velocity for outer mesh on left half of o-grid assign du/dn and dv/dn for outer mesh on right half of o-grid no slip velocity for mesh next to cylinder surface dp/dn=0 on all edges except that at right half of o-grid, p=0 (equal to fixing outlet pressure) Hope someone can give me some help. Thank you. |
September 18, 2006, 08:48 |
Re: BC for o-grid help
Sounds reasonble.
Dont forget to test the result sensitivity to your BC locations. |
September 18, 2006, 17:14 |
what about boundary conditions on symetrical airfoil in O-grid, is that the same as cylinder?
MapFields to New Grid For Extreme Grid Deformations due to Body Motion | albcem | OpenFOAM | 0 | May 5, 2009 15:17 |
Grid Adaptation | Suresh | FLUENT | 0 | October 15, 2003 14:18 |
GRID TO GRID INTERPOLATION in FLUENT | calogero | FLUENT | 3 | June 4, 2003 09:32 |
Combustion Convergence problems | Art Stretton | Phoenics | 5 | April 2, 2002 06:59 |
Troubles modelling flow through a grid | Hans Klaufus | CFX | 1 | June 28, 2000 17:43 |
