How to generate structured tandem airfoil mesh?
Old   September 17, 2006, 10:01
Default How to generate structured tandem airfoil mesh?
CH
I've seen single airfoils are generated as c or o-grid in the structured case. The mesh quality are usually very good.
However, is it possible to generate airfoil in tandem arrangement using structured grids? Preferably, deformation should also be possible.
I've not seen such mesh before. Is it impossible?
Thanks alot
Old   September 19, 2006, 13:55
Default Re: How to generate structured tandem airfoil mesh
pc
Simply stack two C grids one above the other and you have a tandem arrangement.
Old   September 19, 2006, 15:35
Mani
with two C-grids it would be a block-structured grid and you need handling of block-to-block interfaces with your CFD code.
you can use a single block as well, as long as your CFD code has the capability to assign a solid boundary anywhere within the grid.
Old   September 19, 2006, 15:59
pc
Quite right, I was assuming a block-structured topology. I should have been more explicit.
Mesh motion with Translation & Rotation Doginal CFX 2 January 12, 2014 07:21
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 05:24
getting airfoil surface to be recongized for tri mesh josip76 ANSYS Meshing & Geometry 4 June 9, 2011 23:48
Dynamic mesh - structured mesh mrestrepo30 FLUENT 0 June 3, 2009 16:40
unstructured vs. structured grids Frank Muldoon Main CFD Forum 1 January 5, 1999 11:09
