the static pressure at one outlet is negative?
Old   August 15, 2013, 04:04
Default the static pressure at one outlet is negative?
Rong Yue
yuhehuan is on a distinguished road
Hi, my friends, I simulated the pressure distribution in a geometry with pushed air in it. But I got a negative pressure at one outlet. That means the static pressure at this outlet is lower than the static pressure at reference point (101325 Pa). But I guess the pressure at this outlet should be higher than 101325. Because air is pushed from the bottom to the top of the geometry. Maybe the inlet is too close to the outlet. Then I extended the outlet to 5 times of the distance from the original position. And the static pressure are positive .But the mass flow rate at this outlet is positive, which is different with other two outlets.
My questions are: 1. why is the mass flow rate is positive at this outlet? 2. Is the pressure at the original outlet reliable after I extended it to a far distance?
I am so forwarding to your help! Thanks so so much!
Regards,
Rong
The original geometry is like this: Attachment 24418
yuhehuan is offline   Reply With Quote
Old   August 15, 2013, 04:06
Rong Yue
the original geometry
Old   August 15, 2013, 04:07
Rong Yue
the static pressure at inlet and outlets
File Type: jpg static pressure at inlet and outlets.jpg (15.0 KB, 8 views)
Old   August 15, 2013, 04:09
Rong Yue
the geometry after extended outlets
Old   August 15, 2013, 04:12
Rong Yue
the mass flow rate at inlets and outlets after extended the outlets
File Type: jpg massflow rate at inlet and outlets after extended.jpg (18.1 KB, 3 views)
Old   August 15, 2013, 04:14
Rong Yue
the static pressure at inlets and outlets after extended outlets
File Type: jpg static pressure at inlet and outlets after extended.jpg (20.1 KB, 2 views)
Old   August 15, 2013, 04:15
Rong Yue
the mass flow rate at inlets and outlets in the original geometry
Old   August 15, 2013, 22:01
Rong Yue
Does anybody understand my problem? Please! Thanks a lot!
Pressure Driven Supersonic Flow in Converging-Diverging Nozzle cdm OpenFOAM Running, Solving & CFD 7 August 28, 2019 02:37
Modeling transient negative pressure (suction pressure) in outlet N_mrtz FLUENT 1 July 18, 2013 21:59
Question Concerning Pressure Value (Pressure outlet) and Reference Pressure (Physics) andy_flow STAR-CCM+ 1 July 9, 2013 09:44
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 15:11
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 06:13
