combustion in internal combustion engine
Old   September 7, 2006, 15:41
Default combustion in internal combustion engine
George
Hi everybody! I have written a code for 3D unsteady,compressible, turbulent,flow in an internal combustion engine and now the next step is to find the flow of the mixture (air- fuel). Once I find the concentration of the fuel in every finite volume, then I could either follow the main route, which is the combustion, or consider for example that the mixture in that volume is homogenised and if the temperature and the pressure are high enougp, then the mixture will be burned... Any other ideas, in order to avoid to simulate combustion, but find from another method the results of the combustion?
Thank you in advance
Modeling Hyrogen Sealing in an internal combustion Engine anatoliafire Main CFD Forum 0 May 3, 2010 03:40
Tutorial 13 Internal Combustion Engine Wei Siemens 11 March 6, 2009 07:24
Internal combustion engine Akuma FLUENT 0 January 30, 2007 07:02
Internal combustion engine Akuma FLUENT 0 January 30, 2007 03:58
turbulence model in internal combustion engine George Main CFD Forum 0 December 4, 2006 19:01
