Wallpressure output from sloshingtank2D raises questions
Old   July 30, 2013, 23:55
Default Wallpressure output from sloshingtank2D raises questions
musaddeque hossein
musahossein is on a distinguished road
Dear all:
I am modeling a tank 1mX1mX0.1m. Mesh size is 100 Horizontal X 600 Vertical. Water height is 0.4m. The wall pressure is calculated during the interDymFoam run and gives the following output (I am providing a sample here):
# p POINT_DATA 1202
# x y z p
0.05 -0.500525 0 100004
-0.05 -0.500525 0 100004
0.05 -0.500525 -0.00166667 100014
-0.05 -0.500525 -0.00166667 100014
0.05 -0.500525 0.00166667 100002
-0.05 -0.500525 0.00166667 100002
0.05 -0.500525 -0.00333333 100032
-0.05 -0.500525 -0.00333333 100032
0.05 -0.500525 0.00333333 100002
-0.05 -0.500525 0.00333333 100002
0.05 -0.500525 -0.005 100050
-0.05 -0.500525 -0.005 100050
0.05 -0.500525 0.005 100002
-0.05 -0.500525 0.005 100002
0.05 -0.500525 -0.00666667 100068
-0.05 -0.500525 -0.00666667 100068
0.05 -0.500525 0.00666667 100002
-0.05 -0.500525 0.00666667 100002
0.05 -0.500525 -0.00833333 100086
-0.05 -0.500525 -0.00833333 100086
0.05 -0.500525 0.00833333 100002
-0.05 -0.500525 0.00833333 100002
0.05 -0.500525 -0.01 100104
-0.05 -0.500525 -0.01 100104
0.05 -0.500525 0.01 100002
-0.05 -0.500525 0.01 100002
0.05 -0.500525 -0.0116667 100122
-0.05 -0.500525 -0.0116667 100122
0.05 -0.500525 0.0116667 100002
-0.05 -0.500525 0.0116667 100002
0.05 -0.500525 -0.0133333 100140
-0.05 -0.500525 -0.0133333 100140
0.05 -0.500525 0.0133333 100002
Question is:
Are these realistic pressures? and are they in Pascals?
The tank is being laterally displaced with Asin(t/T) where A=0.0145 and T=1.2. So the displacements are very small. So why are the pressures so high? I hope I am missing something here and some one will be kind enough to point out the error to me. Thanks!
musahossein is offline   Reply With Quote
Old   August 2, 2013, 17:39
Default Wallpressure computation in sampleDict
musaddeque hossein
Dear all:
I am modeling a tank LXHXb = 1mX1mX0.1m. My z=0 is at the fluid surface. I am running interdymfoam, sloshingtank2D.
Here is a sample output from the wall pressure:
X Y Z P
0.05 -0.4916 0 100096
-0.05 -0.4916 0 100096
0.05 -0.4916 -0.00166667 100106
-0.05 -0.4916 -0.00166667 100106
0.05 -0.4916 0.00166667 100086
Lets look at the last pressure value: P=100086. My pRefvalue=1e5. My static pressure is: 998.2*9.81*0.4=3916 kg/m^2
So my dynamic pressure=100086-100000-3916=-3830 ( a negative value!). What am I doing wrong here?
high wallpressure, sloshingtank2d, wallpressure
[swak4Foam] outputTime in Swak function immortality OpenFOAM Community Contributions 20 October 6, 2022 13:08
Sloshingtank2D sampleDict Wallpressure musahossein OpenFOAM Running, Solving & CFD 1 February 13, 2017 08:33
mixerVesselAMI2D's mass is not balancing sharonyue OpenFOAM Running, Solving & CFD 6 June 10, 2013 10:34
Questions about data output aki_yafuji OpenFOAM Running, Solving & CFD 3 September 9, 2010 02:59
Some output questions Ogbeni FLUENT 2 September 29, 2005 11:17
