July 25, 2013, 09:28 |
Import_igg_project Indentation problem
Barend de Villiers
Good day Guys.
I'm currently working with Numeca FINE/Design3D and I have to couple a centrifugal compressor to a radial (vaned) diffuser. The script file (.py/python format) used to merge the rows and create the mesh has to import the .igg files for both rows i.e. "def multistage_script_assembly(row1_mesh , row2_mesh , multistage_mesh): import_igg_project("/home/slagter..._222/_dbs/multistage/ImpAnchorRough.igg","row1") import_igg_project("/home/slagter...r_222/_dbs/multistage/DiffWholeMeshRough.igg","row2")". This script is then rewritten for each of the samples flow 1, flow 2 ... and so forth. The problem is that after the defining (def) function the indentation of the import_igg_project ('...') is not seen and hence a indentation error occurs. I've received the script file directly from Numeca and haven't programmed in python much. Any help would be greatly appreciated. Regards. Oom Loot. |
error, import_igg_project, indentation, multistage_script |
UDF compiling problem | Wouter | Fluent UDF and Scheme Programming | 6 | June 6, 2012 04:43 |
Gambit - meshing over airfoil wrapping (?) problem | JFDC | FLUENT | 1 | July 11, 2011 05:59 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 06:29 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
Is this problem well posed? | Thomas P. Abraham | Main CFD Forum | 5 | September 8, 1999 14:52 |
