Modeling Turbulent Horizontal Buoyant Jets
Old   August 29, 2006, 11:27
Default Modeling Turbulent Horizontal Buoyant Jets
Jack Travis
I've searched high and low through the literature to find experimental data and information about modeling turbulent horizontal buoyant jets in a wall free stagnant environment. Think about a large enclosure, maybe 20 meters cube filled with air a STP with a horizontal pipe directed toward the room center, 2 to 5 cm diamater, jetting Helium or Hydrogen between 10 and 50 m/s. There seems to be lots of information about turbulent vertical buoyant jets, but very little about the horizontal configuration.
Has anybody come across experimental data or CFD modeling?
Thank-you, Jack
Old   September 8, 2006, 15:06
Default Re: Modeling Turbulent Horizontal Buoyant Jets
Panos Papanicolaou
We are measuring temperature in horizontal round water jets using fast response thermistors. The apparatus used has a cross section of 1mX0.8m and it is 0.7m deep. The jet diameter is small but the Reynolds numbers used are over 1000.
Let me know what you may need. By December we are going to have accurate measurements. We have performed some preliminary tests so far.
Old   September 11, 2006, 07:36
Jack Travis
Thank-you for your response to my enquiry about horizontal buoyant jets. We're not interested so much in water jets, but in hydrogen and Helium jets into air. In this case we'd have an order of magnitude difference in the jet fluid compared to the ambient air. If you know of any such tests of better yet, 3D modeling studies, I'd be very interested in those.
Turbulent Jets in Water and Air haze_1986 FLUENT 2 October 3, 2011 22:08
Y + in the k-e turbulent modeling SAKTI Siemens 7 July 21, 2008 06:07
Horizontal submerged jets B.B. Morales CFX 3 August 28, 2007 19:24
turbulent modeling with wall functon(or modeling) yoo seon oh Main CFD Forum 5 July 4, 2007 15:06
