IC Engine analysis
Old   July 21, 2013, 13:40
Default IC Engine analysis
Robert Gonçalves
brightfame3 is on a distinguished road
Hello! I hope I am posting this in the correct location. I would really thank a little bit of help, since I have been having some difficulties in this matter.
I intend to do a CFD analysis of an IC Engine for my masters thesis. I have two big doubts about the construction of the model:
1) I intend to create the model in CATIA, mesh it in Pointwise and analyze it in Fluent. Of my knowledge, Fluent can recognize a solid body as a fluid. Therefore, should i construct the model as a solid, or is there another way more recomendable?
2) My other question is the valves. Also, how should I introduce the valves in the body? Create a diferent part, or should i create it within the same body as the cylinder?
Thank you for your time!
brightfame3 is offline   Reply With Quote
Old   July 22, 2013, 17:15
taxalian is on a distinguished road
Send a message via Skype™ to taxalian
Hi, i think you just need to export the surface model as an IGES and then import it into Pointwise. Well i would also construct the valves as surface features in CATIA within the same body as the cylinder.
Hope this helps.
taxalian is offline   Reply With Quote
Old   July 22, 2013, 17:18
Robert Gonçalves
Hi! Thank you for your answer! So you mean I should use the surface design and not the part design correct? I will give it a try and then give you some feedback! Thank you very much!
Old   July 22, 2013, 17:23
Robert Gonçalves
I forgot to ask something.. I am drawing just half of the cylinder. Do i need to put a surface on the symmetric face? Thank you for your time!
catia, fluent, ic engine, pointwise
Combustion analysis of diesel engine unsolver Main CFD Forum 0 October 13, 2012 07:15
Need help for IC engine analysis in basic level tsram90 FLUENT 0 November 3, 2011 07:57
ic engine in-cylinder gas flow analysis george thomas CFX 5 January 29, 2008 08:49
engine flow analysis to find torque maurizio CFX 8 August 13, 2007 03:07
Coolant flow analysis - IC engine Frank FLUENT 2 May 19, 2002 16:59
