Flow past a cylinder. Help needed
Old   July 15, 2013, 11:11
Post Flow past a cylinder. Help needed
Luis
Lurapa is on a distinguished road
Hey guys,
I am dealing with the 2D incompressible flow past a cylinder problem. I am using FV on unstructured meshes with collocated variables (with Rhie-Chow interpolation) and I am employing the SIMPLE algorithm.
The code works fine on the cavity flow problem and other benchmark problems.
My problem comes with the BC (inlet and outlet). Anyone could help me?
Thanks in advance
Lurapa is offline   Reply With Quote
Old   August 18, 2013, 12:25
leflix is on a distinguished road
Hi Lurapa,
Inlet is easy. Generally use U=1, V=0
for outlet many choices are available according the lenght of your domain and your Reynolds number.
you can use dU/dx=0 dV/dx=0
or d²U/dx²=0 dV/dx=0
with mass flow rate correction for outflow velocity so that at the outlet the mass flow rate is ensured and the same as at the inlet.
the most sophisticated outflow BC is the Orlansky BC
dU/dt + Ubarre dU/dx=0
dV/dt + Ubarre dV/dx=0
where Ubarre is the mean velocity in the domain and computed from the mass flow rate.
leflix is offline   Reply With Quote
cylinder, incompressible, simple collocated
Drag Coefficient for flow past a Cylinder o_mars_2010 Main CFD Forum 0 April 18, 2013 07:17
CFD help: flow past cylinder harsha00711 Main CFD Forum 1 December 24, 2010 22:19
flow past a circular cylinder Senthilkumar Main CFD Forum 2 April 20, 2009 00:18
meshing for flow past a cylinder karthik FLUENT 1 July 15, 2005 07:17
flow past a circular cylinder Polina Main CFD Forum 0 June 29, 2005 04:22
