Strange residuals behaviour
Old   July 13, 2013, 15:28
Default Strange residuals behaviour
xxxxx
xxxx is on a distinguished road
Hello everybody.
I'm trying to run a very simple case: a closed volume of water (cylindrical geometry) in which a disk rotates at 303 rad/s around z-axis.
I'm using OF211 and MRFSimpleFoam as solver (MRF steady state solver).
The geometry is very simple and I built a structured mesh (hexa block mesh) of a quarter of the cylinder.
The BCs are:
- rotating disk (including shaft): no-slip walls
- casing : no-slip fixed wall
- cyclic AMI ( = ggi) faces
The case is steady state, k-epsilon turbulence model, I order numerical schemes.
For foam users, I attached the case.
I first run the simulation for 3500 iterations and all seemed "normal ".
Then I restared from time step 3500 to 8500 without changing any thing and the residuals shown the strange to me behaviour that you can see in the picture I attached.
First they seemed to converge, than they grow again and keep higher than before.
The point is that, although this strange behaviour, the fluid fields (velocity, pressure) did not show any important change between before and after and also the z-axis torque monitor shows a monotonous and converging curve (see picture).
Could anyone explain me why there's this strange behaviour?
Federico
xxxx is offline   Reply With Quote
Old   July 13, 2013, 15:40
xxxxx
I also attach the picture of residuals.
Bye.
Federico
strange pressure behaviour with symmetricPlane boudary condition - interFoam duongquaphim OpenFOAM Running, Solving & CFD 10 August 20, 2013 15:00
Strange behaviour when using LienCubicKE and NonlinearKEShih hani OpenFOAM Running, Solving & CFD 20 March 6, 2013 11:06
Strange residuals of the Density Based Solver Pat84 FLUENT 0 October 22, 2012 16:59
kOmegaSST omega residuals strange behaviour zordiack OpenFOAM Running, Solving & CFD 0 August 8, 2012 17:23
Strange Residuals in CCM+ PeterGG Siemens 3 July 27, 2007 13:52
