Pressure BC in SIMPLER Algorithm?
Old   August 24, 2006, 09:43
Default Pressure BC in SIMPLER Algorithm?
Mori
Hi Guys,
I am going to use SIMPLER algorithm in my code. In SIMPLER algorithm, velocity field is guessed and then Pressure equation is solved. I am wondering what would be boundary condition for pressure equation in a lid driven cavity flow. Should pressure consider as zero on all walls?
Thanks for your help.
Mori
Old   August 24, 2006, 19:45
Default Re: Pressure BC in SIMPLER Algorithm?
Halim
If the velocitites are imposed at the boundary like the lid-driven cavity flow and if you uses the staggered grid layout, you do not need the pressure at the boundaries. When you derive the pressure equation just near the bounadry, set pseudo-velocities at the boundary by the real velocities and set the coefficient of the pressure equation (for example, AN for the north boundary) zero. After you calculate flow field, get the pressure at the boundary by extrapolation of inner point values. Read Patankar's book, you may understand what I am talking about.
Halim
Boundary conditions using SIMPLER algorithm lost.identity Main CFD Forum 9 October 25, 2010 19:27
Does star cd takes reference pressure? monica Siemens 1 April 19, 2007 12:26
Gas pressure question Dan Moskal Main CFD Forum 0 October 24, 2002 23:02
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 06:13
Definition of pressure Ola Nordblom FLUENT 1 August 16, 2001 16:58
