July 8, 2013, 10:22 |
Question about turbulence intensity
Meimei Wang
Rep Power: 16 |
Hi
Here is my approach to detect the flow regime for flow in complex geometry: 1) Run the simulation by SST model (or other turbulence model) 2) Look at the turbulence intensity value to know the flow regime Question: 1) Does this approach make sense? 2) What is the range of the turbulence intensity value corresponding to laminar flow? And transitional flow?
Best regards, Meimei |
July 8, 2013, 22:32 |
Rep Power: 15 |
Anna, what is your application? What kind of model is this. Internal flow or external? There is no strict guideline for laminar vs turbulent, it is model dependent. Tell more about the model and what you are trying to get out of it
July 9, 2013, 03:46 |
Meimei Wang
Rep Power: 16 |
This is for internal flow in heat exchanger for electronics cooling. I need to find out the flow is laminar or turbulent. Then I can choose an appropriate model (If it's detected to be laminar, then laminar model. If's it's detected to be turbulent, then SST model.) to resolve the overall pressure drop.
July 9, 2013, 06:00 |
#4 | |
Filippo Maria Denaro
Rep Power: 73 |
make an estimation of your main non-dimensional parameters (Re, Pr, Ra), laminar conditions are very rare in practical applications, the reality is that laminar, transitional and turbulent flow regions often cohexist. |
July 9, 2013, 07:21 |
#5 | |
Meimei Wang
Rep Power: 16 |
Could turbulence intensity value also give a hint?
July 10, 2013, 11:07 |
Meimei Wang
Rep Power: 16 |
Could anyone get a hint about the flow regime from the turbulence intensity value?
Best regards, Meimei Last edited by Anna Tian; July 15, 2013 at 10:30. |
July 11, 2013, 07:13 |
Rep Power: 15 |
I don't work with electronics much so my opinion definitely doesn't count as fact here. Are you calculating re based on channel height or the height of an object that air is moving around? 100 is low enough that I would use a laminar model personally but would make sure my boundary layers are well resolved. Just my two cents
July 15, 2013, 10:30 |
#8 | |
Meimei Wang
Rep Power: 16 |
July 15, 2013, 18:19 |
#9 |
Reza
Rep Power: 17 |
As someone mentioned in previous answers turbulence intensity that you get from simulation is model dependent. In my experience SST was good for internal flows in shutting itself off when flow was laminar, giving very low turbulence viscosity ratios (I ran a case with laminar and SST model, for low enough Reynolds numbers, SST results were close enough to the laminar solution).
However, my suggestion would be to try a transitional model. SST has such an extension (look for Menter's paper on a transitional model for CFD applications). There are also other transitional models and similar to turbulence modeling you might want to try a few and pick the best for your application. These models are going to add a few extra equations to your simulation, so they will be slightly slower than a pure turbulence model. |
specify the turbulence intensity and the turbulence length | bennoman75 | Main CFD Forum | 0 | May 15, 2013 05:36 |
How to asses turbulence intensity | Kwiaci | FLUENT | 0 | September 3, 2012 05:48 |
turbulence intensity --->>> HOW ?? | mohammad | CFX | 6 | February 16, 2012 07:27 |
Inlet Turbulence Intensity | aras | FLUENT | 0 | June 13, 2011 10:21 |
Turbulence intensity scale | Mirek | FLUENT | 1 | May 26, 2004 08:27 |
