July 2, 2013, 05:51 |
problem of convergence
steven
Rep Power: 13 |
Hello everyone,
My cas is of turbumence, a "T" form tube with two cylindres. it has one inlet and two outlets, with the distribution of water, 50% mass flow to each outlet. My problem is that I always have the convergence problems and there are also warnings of reversed flows. I tried the standard wall function, enhanced wall function and realizable model of k-epsilon model, and I also reffined the mesh, extended the outlet, but the situation hasn't been improved. By the way, the Y+ is always between 5 and 30. Do you have any suggestions ? Thank you. Steven |
convergence problem when use pisoFoam, LES for wind tunnel case | Forrest_Lei | OpenFOAM | 3 | July 19, 2011 07:00 |
convergence problem | commonyue | Main CFD Forum | 1 | December 1, 2009 04:54 |
Convergence of CFX field in FSI analysis | nasdak | CFX | 2 | June 29, 2009 02:17 |
3D Fluid Flow Convergence problem | Emily | FLUENT | 2 | March 21, 2007 23:18 |
Non Convergence of 3D Heat transfer cfd problem | Balraj | Main CFD Forum | 3 | December 9, 2004 01:24 |
