Problem with unwanted oscillations
Old   June 29, 2013, 23:19
Unhappy Problem with unwanted oscillations
Patricio Javier Valades Pelayo
patovalades is on a distinguished road
I am trying to write my own Finite Volume code for a very simple problem.
it is a mass transport problem on a pipe. 1D (axial) Unsteady state for the mass balance equation, only forced convection is considered. The Momentum equation on the pipe is considered plug flow (constant at all radius and all axial positions).
In the program I consider an impulse function (delta dirac) of compound A, I made an animation of a plot of Concentration vs Axial Position that changes with time and started and following the pulse (or the evolution of the concentration profile inside the tube).
The pulse moves in the expected way (forward) the width of the peak doesnt change (as expected since there is no axial dispersion), HOWEVER, on the trail behind the pulse I notice some "unwanted" oscillations...
I am using a 1st order in space approximation for the FV and 4th order Runge-Kutta Method. I don't know what to do to get rid of those oscillations, I already tried moving the segments length in the axial direction and the time step, but nothing happens...
I am new to this so all advices are welcome, however I would like to stress that I already checked and reckecked the logic behind the FV volume, and it is all right...maybe some problem with the numerical stability?
patovalades is offline   Reply With Quote
Old   June 29, 2013, 23:33
Here I attach an image of the concentration profile inside the pipe. at time zero the pulse is at Z=0, this image however is taken at time= 22 seconds. The velocity in the pipe is about 0.7 m/s , so the pulse is at about 15-16 meters (about halfway through the pipe since the pipe is 27 m long).
cfl condition, new user, stability problem
[Other] engineFoam new mesh problem ayhan515 OpenFOAM Meshing & Mesh Conversion 5 August 10, 2015 09:45
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 05:43
Numerical oscillations in CFX with water boiling problem. michujo CFX 4 December 16, 2011 10:00
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 06:59
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 20:13
