problem about direct solver for sparse matrix
Old   August 11, 2006, 13:16
Default problem about direct solver for sparse matrix
ztdep
Hi: I just compiled sucessfully a free avalable sparse direct solver under linux OS, I validate my procedure by a simple 2-D heat conduction problem in a square domain with all its four BC=2, so the exact solution is the terperature filed=2 in the square domain! But i have the following problem, when i use the same number of grid points in the x and y direction , i have the exact solution ,but when i set different number of gridpoints in the x and y direction 100by 50, or 5by10, the solution has a large discrepancy between the exact value! the package use a multi frontal method with pivot method! Regards
patching problem unsteady solver yellow-stuff Main CFD Forum 0 September 25, 2009 02:26
UDF problem with Parallel Solver manu FLUENT 0 January 24, 2008 15:31
Can I use coupled solver for this problem Frank FLUENT 0 April 11, 2006 07:28
matrix solver for vector machine TakeharuM Main CFD Forum 1 June 5, 2001 17:16
solver for linear system with large sparse matrix Yangang Bao Main CFD Forum 1 October 25, 1999 05:22
