Icem mesh -> CAD geometry
Old   August 11, 2006, 07:10
Default Icem mesh -> CAD geometry
Ivan
Hi, is it possible to make geometry for CAD from unstruct tetra or hexa Icem mesh?
Regards!
Old   August 13, 2006, 07:28
Default Re: Icem mesh -> CAD geometry
Piet
sure
Piet
Old   August 13, 2006, 09:23
Ivan
What should I do to prepare the geometry model from mesh file? Say, how can I save the geometry in Iges or Parasolid format?
Old   August 13, 2006, 10:38
Piet
there is a function "transfer mesh to facets" it generates a geometrie from mesh press the button and save it as tin then you should be able to export it as step/stl as far as i can remember maybe also iges
try it
Piet
[ICEM] How to generate sunstructured "all-tri patch-dependant" surface mesh in ICEM? jash ANSYS Meshing & Geometry 19 July 23, 2013 19:48
problem when converting mesh (made by ICEM) using fluentMeshToFoam Forrest_Lei OpenFOAM 11 October 16, 2009 07:28
unstructured vs. structured grids Frank Muldoon Main CFD Forum 1 January 5, 1999 11:09
