lid driven cavity by ghia
Old   August 4, 2006, 00:26
Default lid driven cavity by ghia
jj
hello cfd researchers
there are so many authors solved lid driven cavity problem using higher order accuracy , but still every one is using ghias result considered bench mark solution ... what is the special in that . ... i found the only thing is Ghjia use very fine mesh...plz let me know the reason.. thanks
Old   August 4, 2006, 02:03
Default lid driven cavity - experiments
diaw (Des_Aubery)
If I could perhaps add into the 'lid-driven cavity' debate - are there any practical experiments that have been performed that could assist clarification of the many numeric experiments?
diaw...
Old   August 4, 2006, 08:37
Default Re: lid driven cavity - experiments
Andrew Hayes
Ghia's paper is just well written and goes to a high Reynolds Number. I really dont know of any actual experiments though. I still think Gupta's paper is worth looking into, and it is relatively short compared to Ghia's. Also, there is a dissertation online by Debbie Sastrapradja titled, Rayleigh Streaming Simulation Using the Vorticity Transport Equation, that does a good job going through the equations and derivation of the boundary conditions for the streamfunction-vorticity model. It used to be online anyway.
Old   August 7, 2006, 22:03
ztdep
Hi: where is the dissertation online, would you like to tell to the web site! thank you !
Old   August 8, 2006, 08:57
Andrew Hayes
you will have to do a search for it. I can't remember where I found it, but I was able to download it from the web. She went to Penn State
2D Lid Driven Cavity Flow simulation using MATLAB josephlm Main CFD Forum 4 August 17, 2023 21:36
Lid Driven Cavity using Ghost Cell Method and in C++ illuminati5288 Main CFD Forum 0 August 12, 2011 23:05
is there any parallel code for the famous Lid Driven Cavity flow? gholamghar Main CFD Forum 0 August 1, 2010 02:55
[OpenFOAM] Paraview - Lid Driven Cavity kieranhood ParaView 0 February 13, 2010 17:28
Lid driven cavity flow KK FLUENT 1 December 16, 2009 19:10
