Vortex method vs High Reynolds number
Old   August 3, 2006, 12:36
Default Vortex method vs High Reynolds number
Weili
I'm currently working on a code, solving incompressible 3D flow using discrete vortex method. The new idea (probably not that new) for this method is the use of a grid system and finite volume method. But, the problem is that I can only carry out simulations for a Reynolds number lower than 1000, othervise the simulation would become unstable. What could be the reasons for this limitation? the differential scheme ? or grid resolution? Hope someone here could help me out. Thanks
Old   August 4, 2006, 02:15
Default Re: Vortex method vs High Reynolds number
Adrin Gharakhani
I think I have seen a recent paper doing exactly as you suggest; using finite volume methods but using bio-savart law to get the velocities at the finite volume interfaces. If this is what you're doing it isn't new. Hopefully, it's not a thesis material ) (BTW, discrete vortex method has a distinct connotation, which assumes a meshless computation). As for your questions, it's too general ...
Adrin
Two way particle coupling in OF 2.0 and the particle reynolds number preichl OpenFOAM 7 February 9, 2012 16:38
Reynolds Number Matt CFX 0 February 25, 2009 06:40
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 08:36
Reynolds number help Mech FLUENT 0 March 15, 2006 11:28
Multicomponent fluid Andrea CFX 2 October 11, 2004 06:12
