June 13, 2013, 11:38 |
grid normal to wall
Laurien Vandewalle
Rep Power: 13 |
Hi all!
Maybe a very stupid question to you but I only just started studying CFD and I was wondering... Why exactly is it necessary to make the angle between the wall and the grid as close to 90° as possible? It is always done like that but what is the mathematical/physical reason behind it? |
June 16, 2013, 18:06 |
John Chawner
Rep Power: 18 |
When you have boundary conditions that include terms like the gradient of the pressure normal to the wall is zero at the wall it's easier to enforce of the grid is also orthogonal. Also, some turbulence models benefits from having grid lines normal to the wall due to terms involving distance to the wall.
However, I'm certain someone can cite a very good reason why the numerics benefits from orthgonality.
John Chawner / jrc@pointwise.com / www.pointwise.com Blog: http://blog.pointwise.com/ on Twitter: @jchawner |
January 7, 2014, 04:19 |
Wall normal grid in a pipe
SAM
Rep Power: 14 |
Dears
I have question regarding the wall normal grid style: In the Wu and Moin paper (A direct numerical simulation study on the mean velocity characteristics in turbulent pipe flow) the mesh that they used is a bit confusing for me. In the centerline (r=0) the mesh size is 1.845e-3 and at the wall (r=1) is 9.203e-4. But at the distance a bit far from centerline (r=0.409) the mesh size is 9.083e-3 which says 5 time bigger than cenerline. Could please someone help me and explain me the reasean. |
grid, wall |
[Commercial meshers] Fluent3DMeshToFoam | simvun | OpenFOAM Meshing & Mesh Conversion | 50 | January 19, 2020 15:33 |
Natural convection in a closed domain STILL NEEDING help! | Yr0gErG | FLUENT | 4 | December 2, 2019 00:04 |
WALL normal velocity | Luca | Main CFD Forum | 1 | October 8, 2014 05:21 |
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug | unoder | OpenFOAM Installation | 11 | January 30, 2008 20:30 |
Combustion Convergence problems | Art Stretton | Phoenics | 5 | April 2, 2002 05:59 |
