non-orthogonal corrections for convective terms |
June 12, 2013, 13:18 |
Rep Power: 17 |
Hi everyone,
i was just wondering whether someone could explain why there seems in general for unstructured meshes, no mention / worry about non-orthogonal corrections to the face flux values for convection terms as there are for the diffusion terms . for example: in OpenFoam, there are specific correction schemes to deal with mesh non-orthogonality when discretizing the laplacian terms in the N-S equations, but nothing for the convective term. surely, since both calculate face flux values as part of the FV discretization process, there must be an effect just as much on the convective terms due to mesh non-orthogonality as with the diffusion (laplacian) term. many thanks, and regards jonathan |
June 12, 2013, 13:36 |
#2 | |
Filippo Maria Denaro
Rep Power: 73 |
I am not sure if I understand your question... however, in a FV formulation the diffusive flux requires the normal component of a gradient on each surface, the convective flux does not. |
June 12, 2013, 13:55 |
thanks
#3 | |
Rep Power: 17 |
hi Phillipo
ok, so if i understand you correctly, its only the gradient vector at the face which needs to be parallel to the face normal vector, not the flux itself? many thanks regards jon |
Implicit treatment of advection terms and pressure correction | nikosb | Main CFD Forum | 0 | January 17, 2010 17:07 |
Using source terms | jsm | Main CFD Forum | 4 | August 20, 2009 07:44 |
Question in definition of terms in solve | titio | OpenFOAM Running, Solving & CFD | 0 | March 19, 2009 17:02 |
Circular Cylinder at low Reynold number mesh and non orthogonal corrections | kassiotis | OpenFOAM Running, Solving & CFD | 6 | May 15, 2008 07:07 |
K-Epsilon model? | Brindaban Ghosh | Main CFD Forum | 2 | June 24, 2000 05:22 |
