Large 3D tetrahedral meshes
Old   August 24, 1999, 08:49
Default Large 3D tetrahedral meshes
Aldo Bonfiglioli
I'm looking for large 3D unstructured (only tetrahedral) meshes to perform scalabilty tests using an home made CFD code. Eulerian and/or NS meshes would be equally welcome. Beside the NASA Data Set archive: http://www.nas.nasa.gov/Software/DataSets/, I'm not aware of any other source were these could be found (being european I cannot make use of NASA meshes). If anyone out there is aware of available meshes or willing to make available his or her own meshes I would be very grateful to him/her.
Regards, Aldo
Old   August 24, 1999, 16:42
Default Re: Large 3D tetrahedral meshes
chris
Hy, if I understand you correct, you are looking for large tetrahedral meshes. That's really no problem. I think everyone working with cfd has the opposite problem. Well I think that I can help you with large meshes. How much cells do you think ? (But I first want to ask my chief, ok)
Old   August 25, 1999, 09:41
Aldo Bonfiglioli
I would say smthg. of the order of 10^5 meshpoints; I have in mind a test performed on a an M6 wing with 357,900 meshpoints.
Thanks, Aldo
Old   August 27, 1999, 01:50
chris
Sorry, but I do not know what a M6 wing is ..
Old   August 27, 1999, 04:33
Aldo Bonfiglioli
M6 is just a particular wing tested at ONERA for which experimental data are available. Any wing mesh would be suitable. Also channel meshes would be O.K.
[Technical] Automatic Mesh Refinement and Tetrahedral Meshes philippose OpenFOAM Meshing & Mesh Conversion 8 May 21, 2016 16:44
IcoDyMFoam and tetrahedral meshes ulrich_lange OpenFOAM Running, Solving & CFD 11 April 16, 2007 17:44
SFCD in tetrahedral meshes cosimobianchini OpenFOAM Running, Solving & CFD 2 March 6, 2007 12:21
Issues with tetrahedral tetra meshes billy OpenFOAM Running, Solving & CFD 0 May 8, 2006 19:03
[Technical] Tetrahedral meshes Damian Merrick (Merrick) OpenFOAM Meshing & Mesh Conversion 1 December 14, 2004 21:29
