Modeling Solid and Fluid at the same using Interface BC..Help needed
Old   June 4, 2013, 04:41
Default Modeling Solid and Fluid at the same using Interface BC..Help needed
Parampreet Singh
Prince Jassal is on a distinguished road
HELLO EVERYONE,
I AM MODELING AXISYMMETRIC JET IMPINGEMENT WITH 9 JETS PLACED IN AN ARRAY AND ABOVE A HEATED PLATE WHICH RECEIVES HEAT FLUX FROM THE BOTTOM FACE AND THE UPPER FACE OF THE PLATE IS INTERACTING WITH FLUID FROM THE JETS AND AMBIENT. I DID MODELING IN GAMBIT 2.3.16 AND FLUENT VERSION IS 6.3.26,USING 3D MODEL AND INCOMPRESSIBLE PBNS EQUATIONS.
1) USED APPEND FILE TOOL TO SEPARATELY MODEL DOMAIN AND BASE PLATE FILES BOTH AT THE SAME TIME
2) THEN I USED THE BOUNDARY CONDITIONS. IN MY CASE THE HEAT FLUX AT THE BOTTOM FACE IS 8333 W/m2 with A TEMPERATURE OF 313 K AT START.
3) I USED INTERFACE BOUNDARY COND. FOR THE FLUID SOLID INTERFACE ( TOP FACE OF HEATED PLATE) AND ALSO INTERFACE BC WAS USED FOR THE SIDES OF THE PLATE AS WELL
4) PROBLEM PART IS :- HOW DO I INPUT THE BOUNDARY COND FOR THESE SIDES AND THE TOP WHEN THEY ARE INTERFACE AS IN MY PROBLEM THE SIDES ARE INSULATED AND THE TOP FACE IS RECEIVING HEAT FROM THE BOTTOM ONE.HOW TO INPUT BC's FOR THESE..AND ALSO HPW TO PLOT TEMPERATURE CONTOURS FOR THESE????
PLEASE HELP
Prince Jassal is offline   Reply With Quote
Old   June 12, 2013, 06:07
Rami Ben-Zvi
Rami is on a distinguished road
1. What happened to your lower-case keyboard?
2. You better submit this post to the Fluent forum.
Rami is offline   Reply With Quote
Wind turbine simulation Saturn CFX 60 July 17, 2024 06:45
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 18:44
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 08:00
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
