Time-accurate preconditioning for LES/DNS of turbulent flows
Old   May 31, 2013, 17:20
Default Time-accurate preconditioning for LES/DNS of turbulent flows
Francesco Capuano
francesco_capuano is on a distinguished road
Dear all,
I have some some questions and doubts regarding the use of compressible codes for solving low-Mach (order 0.01-0.1) turbulent flows (using LES or DNS).
The main question is the following: is it really necessary to use time-accurate preconditioning techniques (e.g. dual-time stepping) for turbulent computations?
Some LES codes do that, but some others simply use an explicit time-integration with small time-steps. I don't quite understand whether the use of preconditioning is a matter of time-step restriction, accuracy, or both. Any experience on that?
Thanks in advance.
francesco_capuano is offline   Reply With Quote
Old   May 31, 2013, 18:13
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Originally Posted by francesco_capuano View Post
Dear all,
Thanks in advance.
my opinion is that a pure compressible code could work at low Mach without preconditioning provided that the scheme is very accurate and the time step is constrained by the CFL condition based on the sound velocity.
Accuracy is important as also small errors in computing the density can result in high pressure perturbation.
FMDenaro is offline   Reply With Quote
Old   May 31, 2013, 19:13
cfdnewbie
cfdnewbie is on a distinguished road
We use explicit time integration (with proper CFL bounds) all the time for Ma=0.1 computations, both LES and DNS and haven't encountered any problems.
cfdnewbie is offline   Reply With Quote
dns, les, preconditioning, turbulent flows
TimeVaryingMappedFixedValue irishdave OpenFOAM Running, Solving & CFD 32 June 16, 2021 07:55
High Courant Number @ icoFoam Artex85 OpenFOAM Running, Solving & CFD 11 February 16, 2017 14:40
dynamic Mesh is faster than MRF???? sharonyue OpenFOAM Running, Solving & CFD 14 August 26, 2013 08:47
Full pipe 3D using icoFoam cyberbrain OpenFOAM 4 March 16, 2011 10:20
time averaged heat transfer in oscillating flow Matthieu Ubas Main CFD Forum 2 November 5, 1999 15:20
