DNS of Re 3900 cylinder flow
Old   May 30, 2013, 13:01
Default DNS of Re 3900 cylinder flow
cfdnewbie
cfdnewbie is on a distinguished road
Hello fellow researchers,
I'm looking for DNS results of the standard RE 3900 cylinder test case. I have done a literature search on this topic, and the "largest" DNS I found is in here: http://www.cfm.brown.edu/people/gk/jfm_re10K.pdf (with a reference to a paper by Ma with a similar resolution). Do you happen to know of any more recent DNS of this flow, preferably with a higher resolution? I'm looking for the best reference possible for this case, and I am trying to judge whether it is worthwile doing a higher resolution DNS of this flow.
Thanks a lot, have a great weekend!
cfdnewbie is offline   Reply With Quote
Old   May 30, 2013, 15:04
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
Mesh in journal paper is too coarse
Far is offline   Reply With Quote
Old   May 30, 2013, 15:53
cfdnewbie
Do you have a recommendation for what the mesh should look like? Why do you think the mesh in the paper is too coarse?
Old   May 30, 2013, 16:05
Far
Sijal
1. It should be hexa/map mesh
2. It should follow DX, DY and DZ requirements of DNS mesh
Old   May 30, 2013, 16:11
cfdnewbie
hm, why would you say that? there are two in the paper. One is on hexas, the other on tetras. As long as the resolution is close to a DNS, it doesn't make a difference.
It seems that the resolution they are using does that, doesn't it? They have a grid point at 0.32 based on the friction velocity...that sounds sufficient to me, or am I misunderstanding somehting?
The only thing that bothers me somewhat is that they use only about 14mio of DOF for this case...that seems not too much for today's standards, but of course that was in 2000....
Old   May 30, 2013, 16:13
Far
Sijal
There are two meshes. One is low resolution tetra and second is high resolution tetra
Old   May 30, 2013, 16:19
cfdnewbie
The second tetra (9272 elems) has about 24mio grid points, the second hex mesh they are talking about has less than that (about 14mio). So the highest number of DOF is indeed 24 mio, which seems to me not too much for a DNS - and certainly easily surpassed with today's codes.
Old   May 30, 2013, 16:26
Far
Sijal
Could you please explain what is meant by 9272 elements and how it is equivalent to 24 million grid points.
Old   May 30, 2013, 16:30
cfdnewbie
They are using a 5th order Jacobian basis in each hex. Most likely, that's 6*7/2 DOFs per element, at least that's the standard approach on tets. So each 2D plane has about 9000 * 21 = 189000 DOF. Times the Fourier nodes (128), thats about 24 mio.
flow around a cylinder pXYZ Main CFD Forum 14 July 25, 2011 11:05
1 Was FSI for a flow over a cylinder vmlxb6 CFX 17 May 16, 2011 03:29
reference calcultion, flow around a cylinder butch85 Main CFD Forum 3 January 31, 2011 17:10
Flow past cylinder (Re=10^5) lbeaudet Main CFD Forum 9 June 2, 2009 04:59
Flow around a cylinder at subcritical regime. yousef FLUENT 0 March 18, 2006 10:18
