add/removal of grid lines
Old   July 26, 2006, 20:40
Default Re: add/removal of grid lines
  #21
George
Well, unfortunately I don't know any croatian...Only english, german and greek. I am trying to follow your instructions, which is a little bit different from what I was doing until now. Tomorrow I will have some results on how effective it was. I will let you know. One more question, in order for the interpolation to be conservative, what should I do different from usual?
Thank you in advance!
Old   July 27, 2006, 19:38
  #22
George
Well, I did not manage to follow the methodology that you advised me to do. Not because the one that I follow is better, but my code takes too much time to be compiled. It is around 15000 lines and I have only a Pentium 3 processor and the compilation takes around half an hour, so any tests that I make should be very-very carefully planned. But I will try tomorrow maybe. Thank you again for your time!
how to Turning grid lines off hsnclk FLUENT 1 April 19, 2011 02:39
Parallel partion lines on grid Allan Walsh FLUENT 1 January 12, 2009 19:09
coloured grid lines instead of contours Matthias FLUENT 8 December 10, 2008 20:09
Tecplot - Display Grid Lines asd Tecplot 1 June 29, 2007 03:34
Combustion Convergence problems Art Stretton Phoenics 5 April 2, 2002 06:59
