Capturing Large Variations using FINITE DIFFERENCE
Old   August 20, 1999, 07:32
Default Capturing Large Variations using FINITE DIFFERENCE
Yogesh Talekar
Hello "Gurus",
I am doing a 1-D flow using finite difference in Conservation forms. There are quite a large variations in density and velocity expected towards the END side. And boundary values are calculated using LINEAR EXTRAPOLATION.
The program develops HUGE VALUES of density and velocity and goes unstable towards the BOUNDARY END-SIDE.
Other grid points away from boundary are OKEY. Shall I increase the grid-size or REDUCE the time-step?
Can anybody help?
Old   August 20, 1999, 13:21
Default Re: Capturing Large Variations using FINITE DIFFERENCE
John C. Chien
(1). What is the problem you are trying to solve? (2). Based on your description, it is hopeless. You have both the accuracy problem and the stability problem. (3). It is a good idea to look for a working method first.
Finite element vs. finite difference Francisco Saldarriaga Main CFD Forum 23 December 17, 2014 09:21
natural convection induced by radiation. large temperature difference! uncle_salty FLUENT 0 February 3, 2010 12:57
Finite difference can be non-conservative? gregmason Main CFD Forum 2 July 8, 2009 12:53
Fininte difference and Finite element Technique Mahendra Singh Mehra FLUENT 3 December 23, 2005 00:49
finite difference method for navier-stokes problem dallybird Main CFD Forum 5 February 17, 2003 23:00
