NEUMANN BOUNDARY CONDITION IN MESHLESS METHODS |
July 14, 2006, 06:53 |
Hi, dear friends,
I am trying to solve the Poisson equation on a retangular by using Neumann and Dirichlet boundary conditions. In the numerical method there is no mesh. We work with points distributed in the geometry. My question is this: "How to apply the Neumann boundary condition?" Thank you a lot, Kemelli |
July 14, 2006, 09:19 |
Re: NEUMANN BOUNDARY CONDITION IN MESHLESS METHODS
How do you discretize the Poisson equation, i.e. how do you describe derivatives using the control points? You must know that,... and your question should answer itself.
July 15, 2006, 01:41 |
I can think of two approaches, which may be called strong and weak implementations.
Strong 1 You already have a formula for the derivatives. Plug them into the Neumann condition and solve for the boundary value. Strong 2 If you are using least squares for approximating derivatives, use a Lagrange multiplier to include the Neumann condition. Weak If you are using least squares, square the Neumann condition and add it to the quantity you are minimizing. |
Mixed/Robin boundary condition | aaev | OpenFOAM Bugs | 2 | December 15, 2011 14:03 |
How to set the Heat Flux boundary condition at Outlet | creddy_trddc | CFX | 3 | September 21, 2011 07:44 |
UDF : Neumann boundary condition | PierreM | FLUENT | 1 | December 5, 2008 07:06 |
Rotating interpolated boundary condition | hani | OpenFOAM Running, Solving & CFD | 0 | July 4, 2006 07:09 |
New topic on same subject - Flow around race car | Tudor Miron | CFX | 15 | April 2, 2004 06:18 |
