How to calculate the vehicle front/rear lift forces
Old   May 17, 2013, 06:03
Default How to calculate the vehicle front/rear lift forces
Fayong.zhang
zhang6425532 is on a distinguished road
How to calculate the vehicle front/rear lift force? I know how to calculate the whole car lift force, but how to calculate the front/rear lift force separately?
zhang6425532 is offline   Reply With Quote
Old   May 17, 2013, 07:30
Lefteris
Aeronautics El. K. is on a distinguished road
Which software are you using?
Lefteris
Aeronautics El. K. is offline   Reply With Quote
Old   May 17, 2013, 11:15
Fayong.zhang
Star-ccm+ and fluent both ok
Old   May 19, 2013, 09:19
Gajendra Gulgulia
ggulgulia is on a distinguished road
Hey Zhang
I am not giving you a software custom method to calculate the vehicle lift. What I am about to mention in the foregoing discussion is a standard method for calculating the lift/drag forces at any region of the body
The region of interest has to be explicitly defined in the code. For lift coefficient calculation you need to have the area (Vector) of the region normal to the longitudinal direction of the vehicle, say A, and the density of the fluid flowing over the surface of the vehicle, say d, The force has to be calculated by the expression in the code you will be using (all of the softwares nowadays have an inbuilt expression to calculate the force on the surface of interest. This force, say F, is fund out by running the simulation. Then you can create a custom expression to get the force coefficient and running the same in iteration. The following formula has to be used for calculating the force coefficient:
C= F/(0.5*d*A)
For drag coefficient F is along the direction opposite to the fluid flow or along the direction of the area vector, and for lift coefficient F is along the direction aligned with the vertical of the local coordinate system
ggulgulia is offline   Reply With Quote
Old   May 19, 2013, 09:21
Gajendra Gulgulia
.. and yeah if you are using STAR CCM+ , you can get the example in one of the tutorials given in the help file of the package
PS sorry for the long reply posted previously.. it's just that I emphasize a lot in keeping the basics clear
Old   May 19, 2013, 14:23
kyle is on a distinguished road
You can get the aerodynamic lift, drag and moment from your CFD software and then do some very simple static analysis to determine the aerodynamic load on each axle.
kyle is offline   Reply With Quote
Old   May 19, 2013, 14:50
Lefteris
I think that in Fluent you can choose the surface that you want and have it calculate the aerodynamic forces on these surfaces. I'm not so sure about that though.
Originally Posted by ggulgulia View Post
... and for lift coefficient F is along the direction aligned with the vertical of the local coordinate system
Lift is in the direction perpendicular to the flow direction.
Lefteris
Lattice Boltzmann, LIFT and DRAG forces Puigar Main CFD Forum 2 May 30, 2024 07:58
using forces for geting drag and lift force magnitude? 510_ Main CFD Forum 2 October 28, 2010 12:42
how to calculate forces on the wall with free surface? phsieh2005 Main CFD Forum 2 July 13, 2010 09:11
Trying to calculate lift and drag forces vkrastev OpenFOAM 0 January 27, 2010 12:33
Calculate forces without hydrostatic pressure geir_oye FLUENT 4 November 12, 2009 10:12
