How to dispose CFD software for best performance
Old   May 8, 2013, 08:12
Default How to dispose CFD software for best performance
acasas's Avatar
Antonio Casas
acasas is on a distinguished road
Hi, all.
I´m new in CFD and FEA, and I´m not sure how to dispose the software for maximum performance. Should I install O/S and the CFD software in separated hard disk?
and yet should I use another separate disk for the files, and another for the temporary memory access? If not all my disks have the same speed, wich one should I use for each task? The fastest for the O/S, for CFD software, for the files , or for the temporary memory access?
Thank´s
acasas is offline   Reply With Quote
Old   May 8, 2013, 08:38
Lefteris
Aeronautics El. K. is on a distinguished road
Buy an SSD disk and install your OS, the CFD software and everything else in there.
Lefteris
Aeronautics El. K. is offline   Reply With Quote
Old   May 8, 2013, 09:01
acasas's Avatar
Antonio Casas
thank´s, lefteris.
If I do have several SSD disks, of different size and speed, I still do have the same questions. What would be the best arrngement for best performance?
thank´s
Old   May 8, 2013, 09:23
Lefteris
I believe you need only 1 SSD disk about 120GB where you install everything. Personally, I have the OS, the cfd softwares and the working folders (I mean a folder for each case I work on) for the softwares at the same drive and the other files that are unnecessary for cfd are on another drive. I don't know about memory access though.
Lefteris
Old   May 8, 2013, 09:27
acasas's Avatar
Antonio Casas
mmm, ok, well thank´s for your prompt answers. I´ll be investigating about this topic. I´ll post it in here if I get it more clear.
Thank´s
Old   May 8, 2013, 09:32
Lefteris
There's a section here dealing with hardware topics. The guys there are definitely more informed on such matters than I am.
http://www.cfd-online.com/Forums/hardware/
Lefteris
Old   May 8, 2013, 12:09
acasas's Avatar
Antonio Casas
I know lefteries, I did also posted the question over there, but seems that people in hardware forum section don´t know much about hardware.....
anyway, maybe I need to wait a litle more for someone to help me on this.
Again, thank´s for your interest.
Old   May 8, 2013, 12:19
Lefteris
Be patient They'll reply!
Lefteris
Old   May 13, 2013, 08:47
Thumbs up
RZA
Engr.RZA is on a distinguished road
Try OpenFoam its free CFD code..
Engr.RZA is offline   Reply With Quote
Old   May 13, 2013, 17:21
Ford Prefect's Avatar
Ford Prefect is on a distinguished road
Originally Posted by acasas View Post
Hi, all.
Thank´s
Disk access should be a really small part of your total analysis time. If you do not have enough memory (RAM) and need to use swap memory from HDD then you need to decrease problem size or get more memory.
"Trying is the first step to failure." - Homer Simpson
Ford Prefect is offline   Reply With Quote
What is the optimal (economically and user friendly) CFD software for my application? Rame Main CFD Forum 0 August 10, 2009 06:30
ThermoForming CFD software Patxi Main CFD Forum 4 December 5, 2003 23:54
ASME CFD Symposium, Atlanta, 22-26 July 2001 Chris R. Kleijn Main CFD Forum 16 October 2, 2000 10:15
ASME CFD Symposium, Atlanta, July 2001 Chris R. Kleijn Main CFD Forum 0 September 13, 2000 05:48
Get a free or low price CFD or engineering estimate software about micro air vehicle. QingHua Zeng Main CFD Forum 3 May 16, 2000 12:04
